TEO 2.2.0 HOTFIX
kruppate
Hello there,
I was trying to install TEO Client on my laptop (win 7-os) but got authentication error,so i got solution that need to install HotFixes..so..
I want to install this HotFixes ...so..does anybody know how to install these ? i mean do i have to install after the fresh TEO installation or on existing TEO installation for which i had error ?
please help me for this installtion...appreciate you..
Krupesh
Shaun Roberts
With your TEO client, you'll need to have trust relationships if you are doing cross-domain work I believe.
If you want to install HotFixes, just download the hotfixes, unzip them and install them (follow instructions in HF) on your TEO server. You must have TEO up and running to do this of course.
You can find the TEO hotfixes for download @ cisco.com
If you are internal you can find them @ http://wikicentral.cisco.com/display/IABUS/TEO+Hot+Fixes
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Shaun Roberts
--Shaun Roberts
shaurobe@cisco.com
Hello christopher,
Thank you very much....I will download those fixes..my TEO up n running...
Krupesh
