TEO installation error 1001
kruppate
Hello there,
I was trying to install TEO on my virtual machine...i did installed database and all pre. software and i did go through last step of TEO installation.
When i was at last step i got this error " Error 1001" and i hit next it was uninstall TEO means reverse...the process...
Does anybody know why is this happen ?
Please share information...appreciate you...
Krupesh Patel
Shaun Roberts
1001 is a generic Microsoft Installer error. It could be one of many things. We've seen it be anything from permissions issues, to crypto containers, to bad username/password, etc. This cannot be trouble shot without logs from TEO and without probably seeing it in action.
Meaning you need to open a TAC case and work with my team on it. Please open a sev 3 case and someone form the team will be assigned to work with you.
thanks,
Shaun Roberts
TEO Support lead
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
Shaun Roberts
thanks,
Shaun Roberts
TEO Support lead
--Shaun Roberts
shaurobe@cisco.com
Thank you very much Christopher....
i will open case ...but before that i wana try to try one more time because TEO i already installed and afterwhile i had issue with updates and i need to uninstalled ...and secondtime when  i was try to install ..i got this error 1001...so let me try and if i will not get luck han i will open case..
Krupesh
