Tidal Refresh
tlakshma1
Hi All,
Our Tidal application is not refreshing periodically. Every 30 mins i have to close and open the application to see the updated job status.
Tidal Version: 5.3.1
Master: Unix
Is there way to avoid this issue. Any help will be greatly appreciated.
Thanks!
Best Regards,
Thamil
Marc Clasby
Job Activity pane should be updated automatically every 30 seconds or so (depends on DB / # of jobs)
try F5 first then View.. refresh all data
I have seen what you descibe a few times
When in doubt I do a file... New Console, then close the one that is not working (usually does the trick)
You can also find a bit of help in the help
View Menu..
Save Desktop <-- when you get it working
Save on Exit <-- usually I uncheck this when the client acts flaky
Restore Desktop <-- could recover desktop to last save settings
you may have to terminate your saclient.exe running on your desktop (Task Manager) then restart it.
Thanks Marc. I will try your last option.
