Tidal Time Window blanked
James Solecki
When editing a SQL job where only the job name was changed, the Time Window for the start and end times are blanked out when the job is saved. I also noticed it when editing a step name and this also occurs for a Windows Agent job. When viewing the Time Window, it is there before I save (I did not click and edit the time). Is this a known issue and is there a fix for it? Currently, the workaround is to edit the time whenever the job is modified.
Thanks.
Michelle Morris
I haven't noticed this behavior.  What version of client and master are you running?
Michelle
It is Cisco Tidal Enterprise Scheduler version 6.0.2.94 for both Master and Client. I tried with both IE and Firefox and the db is installed on a SQL 2008. (not R2). Let me know if I need to provide further information. Thanks.
