Unable to customize condition branch
pierreprost
I'm having a strange issue where I want to put some content in Starter Edition "Virtual Server Post-provisioning" process which sould be allowed as this process has the "workflow" customizable flag.
I've been able to add some activities but when it comes to a condition branch, I can add it but not configure it, see screenshot below:
Any hint on what I'm doing wrong ?
Pierre
Shaun Roberts
Looks like there could be an issue. Please open a TAC case with your support contract and let TAC review and then raise to engineering if needed.
-Shaun Roberts
CPO/CIAC Support Team Lead
shaurobe@cisco.com
--Shaun Roberts
Principal Engineer, CX
shaurobe@cisco.com
It is a known issue (CSCuc53851) getting fixed in PO 2.3.4 (IAC 3.1). A hotfix for 2.3.2 may be need.
Hi Julio,
Thank you for your answer.
I am running Starter Edition 3.0.1 with CPO 2.3.0 and fololowing patches :
- 2.3.0 Hotfix1
- 2.3.0 Hotfix2
- 2.3 Content Update 1
Which gives this:
Which patches do you suggest I apply ?
Thank you.
Pierre
Julio is saying there is no hotfix for it currently. If you needed this fixed before 2.3.4 and had a valid business use-case, you need to open a TAC case and submit the issue and request it be hotsited.
-shaun
--Shaun Roberts
shaurobe@cisco.com
