Upgrading from TES 5.3.1 to TES 6.2.1 - Oracle Apps
Is there anyone successfully running Oracle Apps after upgrade to TES 6.2.1?
I am having so many problems, it does not allow me to change Oracle Apps Job paramaters for several standard Oracle eBis programs such as "Payables Transfer to General Ledger".
Thanks, Lam
Joe Fletcher
Have you checked the release notes for SP2. There appears to be a number of fixes for the Oracle Apps adapter included.
Cheers
Hi Joe,
We've just applied SP2 and now nothing working for us.
Services are up, but we are unable to launch Tidal from Web Client, after sign on, I am getting:
Directory: /client/
3B12909AF5DB9CF8A8236662A7F7CFCE.cache.png.gz 201943 bytesMay 6, 2015 9:37:48 PM
714AF47EB0459FE71B43BD8E0F8803E6.cache.html.gz 102195 bytesMay 6, 2015 9:37:48 PM
7DDC5FA828A3FDC656BCEA34D35C7472.cache.html 318389 bytesMay 6, 2015 9:37:48 PM
965704074C27F4136ADDCB2AF7979AAC.cache.html 315353 bytesMay 6, 2015 9:37:48 PM
965704074C27F4136ADDCB2AF7979AAC.cache.html.gz 101293 bytesMay 6, 2015 9:37:48 PM
AD42B3151177EB6156EC55D0378B6071.cache.html.gz 101777 bytesMay 6, 2015 9:37:48 PM
I have submitted a new case through Cisco Support.
Thanks, Lam
I had a problem with this too when I tested it. Initially I used the upgrade script. This apparently broke everything. My fix was to restore my original version and use the manual upgrade method.
Hi Joe,
With Cisco support, we applied SP2 manually and we are now able to launch TES 6.2.1 SP2.
Unfortunatly I am still having problem entering parameters for Oracle Apps jobs. I will get the log files and submit to Cisco support to investigate.
I would like to know if anyone out there has successfully running TES6.2 and have no issue with Oracle Apps Jobs.
Thanks, Lam
