06-11-2015 06:43 PM - edited 03-01-2019 09:15 AM
Is there anyone successfully running Oracle Apps after upgrade to TES 6.2.1?
I am having so many problems, it does not allow me to change Oracle Apps Job paramaters for several standard Oracle eBis programs such as "Payables Transfer to General Ledger".
Thanks, Lam
06-12-2015 07:46 AM
Have you checked the release notes for SP2. There appears to be a number of fixes for the Oracle Apps adapter included.
Cheers
06-14-2015 06:16 PM
Hi Joe,
We've just applied SP2 and now nothing working for us.
Services are up, but we are unable to launch Tidal from Web Client, after sign on, I am getting:
3B12909AF5DB9CF8A8236662A7F7CFCE.cache.png.gz | 201943 bytes | May 6, 2015 9:37:48 PM |
714AF47EB0459FE71B43BD8E0F8803E6.cache.html.gz | 102195 bytes | May 6, 2015 9:37:48 PM |
7DDC5FA828A3FDC656BCEA34D35C7472.cache.html | 318389 bytes | May 6, 2015 9:37:48 PM |
965704074C27F4136ADDCB2AF7979AAC.cache.html | 315353 bytes | May 6, 2015 9:37:48 PM |
965704074C27F4136ADDCB2AF7979AAC.cache.html.gz | 101293 bytes | May 6, 2015 9:37:48 PM |
AD42B3151177EB6156EC55D0378B6071.cache.html.gz | 101777 bytes | May 6, 2015 9:37:48 PM |
I have submitted a new case through Cisco Support.
Thanks, Lam
06-15-2015 01:33 AM
I had a problem with this too when I tested it. Initially I used the upgrade script. This apparently broke everything. My fix was to restore my original version and use the manual upgrade method.
06-15-2015 11:00 PM
Hi Joe,
With Cisco support, we applied SP2 manually and we are now able to launch TES 6.2.1 SP2.
Unfortunatly I am still having problem entering parameters for Oracle Apps jobs. I will get the log files and submit to Cisco support to investigate.
I would like to know if anyone out there has successfully running TES6.2 and have no issue with Oracle Apps Jobs.
Thanks, Lam
