Upgrading to TES 6.03
Chris Davis
We are planning on upgrading to 6.03. Currenlty we are running MSSQL2005.  Would you recommend us to move to 2008 before we upgrade or should we upgrade to 6.03 and then upgrade the DB then?
Thanks.
Michael Durette
We have the same question, but also does 6.0.3 support SQL2012 version?
If I were doing the upgrade, I would upgrade SQL to the new version, let Tidal run for a week or two and then upgrade Tidal to the new version.  I feel like that would give you an idea of how Tidal and the new SQL work together before adding the new Tidal to the mix.
I can't answer the SQL 2012 question.
Michelle
shsteven
TES 6.0.3 supports MS-SQL2012 for both the TES Master & Client Manager.  An update is available to the Client Manager installation package that directly addresses MS-SQL2012 suppoort and can be provided by contacting the TES support team.
-Shane
