2811 ISR w/Voice Bundle Missing Files
srcasella
We purchased two 2811 ISR routers with voice bundles for our school. Unfortunately, someone deleted all of the files from flash while attempting to configuration them.
We uploaded the voice IOS but don't know which additional files were included as part of the default configuration.
We're in search of the list of files which came on the 2811s and where to track them down on Cisco's Web site. These files must have included the default configurations files, loads, firmware, etc.
We had handsets working but them no longer register. They generate an alarm and an error on the handset. However, IP Communicator works perfectly.
Thank you.
Steven Holl
It sounds like this is CME?
Technically, all you need are the IP phone loads for the IP phones you have registering to this box.  Basically, everything in the configuration (show start) that starts with tftp-server.
If you want to run the CME GUI, have ringtones, MOH, BACD, etc, then that stuff if all found in the CME ZIP file.
-Steve
