3rd Party SIP Phone incoming call issue
LalitArora89
Hi all
i have registered Avaya 9611 & 9641 IP phone to CUCM 11.5
below is the issue summary.
whenever avaya phone tries to reach  Cisco IP phone on same call manager it able to make outbound call however when  Cisco phone try to reach same avaya phone it disconnect after ~40seconds and avaya phone didnt ring.
as per logs i could see erro 408 request timeout.
can anybody help me on this?
attaching logs.
Lalit Arora
2 Accepted Solutions
LalitArora89
Noticed that the Alert-Info Header is causing the problem, part of the INVITE message being sent out to AVAYA Phone (Third Party SIP device in my case).
Alert-Info: <file://Bellcore-dr1/>
1. Configured a SIP Normalization Script to remove the Alert-Info Header from the INVITE message.
2. Applied the Normalization script to a SIP Profile.
3. Applied the SIP Profile to the Avaya Phone.
4. Test calls were successful both-sided with proper 2-way audio communication.
Remove Alert info header from SIP invite from cisco to avaya..
00488629.001 |04:11:55.670 |AppInfo  |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 192.168.16.75 on port 3438 index 854
[27101,NET]
INVITE sip:1214@192.168.16.75:3438;transport=tcp;avaya-sc-enabled SIP/2.0
Via: SIP/2.0/TCP 192.168.16.101:5060;branch=z9hG4bKc31135f3c8
From: <sip:2002@192.168.16.101>;tag=9020~9aafa914-4115-4ccf-8a6e-e11e17c4aabc-32432700
To: <sip:1214@192.168.16.101>
Date: Mon, 18 Sep 2017 11:11:55 GMT
Call-ID: 2cbf5500-9bf1a9fb-ae-6510a8c0@192.168.16.101
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CP9971/9.4.2
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Send-Info: conference, x-cisco-conference
Session-ID: 43b2d1ab923ac67a51a982a283aa9019;remote=00000000000000000000000000000000
Remote-Party-ID: <sip:2002@192.168.16.101;x-cisco-callback-number=2002>;party=calling;screen=yes;privacy=off
Contact: <sip:2002@192.168.16.101:5060;transport=tcp>
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 204
v=0
o=CiscoSystemsCCM-SIP 9020 1 IN IP4 192.168.16.101
s=SIP Call
c=IN IP4 192.168.16.101
t=0 0
m=audio 24608 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
00488630.000
Source Filename: SDL001_100_000026.txt
LalitArora89
[27101,NET]
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 204
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
00488630.000
