7811 SelfCare
Paulo Ferreira
we have a CUCM 10.5 and in SelfCare page the image of 7811 doesn´t appears.
I just found a bug related to 7841 in version 10, but with that model we don't have problem, the imagem appears.
Any clue?
Paulo Ferreira
Jaime Valencia
CSCus58493    there is no picture for 7811 phone under ccmuser side
java
if this helps, please rate
Jaime Valencia
java
Hi Jaime,
thanks for your response.
I can´t see that bug:
Insufficient Permissions to View Bug
This bug contains proprietary information and is not yet publicly available.
Then you either need to log a TAC case, or reach your SE for further assistance with that bug, if it's not publicly available.
java
Ok Jaime,
thanks for your precious help.
Best regards
