7821 Unprovisioned Status
TeleCare
Dear community
I have 2 Cisco IP phone model cp-7821 with the following configuration:
voice register dn 15
number 115
name phone1
voice register pool 2
id mac 701F.534C.FD0A
type 7821
number 1 dn 15
voice register dn 22
number 222
name phone2
voice register pool 3
id mac 701F.534C.FC3F
type 7821
number 1 dn 22
Phone1 registered successfully but phone2 stuck at provisioned, I checked the network setting and I found that TFTP IP appearing and all setting correct, may you please tell me what might be the problem?
Put the command create profile under voice register global and try again.
Also,share the output of show voice register global tftp-
Hi Mohammed
When I enter "create profile " under voice register global, this message appears:
"%Error deleting flash:/its/jabber-config.xml (No such file or directory)"
and below the output of Show voice register global
CUCME-Router#show voice register global
CONFIG [Version=10.5]
Version 10.5
Mode is cme
Max-pool is 30
Max-dn is 100
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 172.16.30.2 port 5060
Time-format is 12
Date-format is M/D/Y
Time-zone is 5
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Forwarding local is enabled
Video is disabled
Camera is disabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is disabled
Dst auto adjust is enabled
start at Apr week 1 day Sun time 02:00
stop at Oct week 8 day Sun time 02:00
Max redirect number is 5
IP QoS DSCP:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for service
Telnet Level: 0
Tftp path is flash:/its
Generate text file is disabled
Tftp files are created, current syncinfo 0001975019401329
OS79XX.TXT is not created
timeout interdigit 10
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
MWI unsolicited notify is disabled
Active registrations : 3
Total SIP phones registered: 3
Total Registration Statistics
Registration requests : 5
Registration success : 5
Registration failed : 0
unRegister requests : 2
unRegister success : 2
unRegister failed : 0
Attempts to register
after last unregister : 0
Last register request time : *20:48:59.926 UTC Tue Nov 21 2017
Last unregister request time : *20:52:16.455 UTC Tue Nov 21 2017
Register success time : *20:48:59.926 UTC Tue Nov 21 2017
Unregister success time : *20:52:16.455 UTC Tue Nov 21 2017
