7940-7960 Handset programming codes
jharwell354
Hey guys,
Is there a reference guide that lists all of the programming codes that can be entered from the handset? For example, 21002 for the MWI or the factory reset procedure.
Jeff
Jaime Valencia
Yes and no.
No, because MWI is something YOU configure so there's no way we can have a guide with that.
Yes, because there is a factory reset which applies to any phone.
There are some things like **# to unblock the settings or **#** when in settings to reset the phone that are in some other docs, but we don't have one with all of the things you can enter in a phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
