05-07-2017 05:44 AM - edited 03-17-2019 10:16 AM
I spent all my free time in the last three days trying to figure out how to successfully register a 7960G as a SIP phone in CME8.6 running on a 2811.
I already have two CIPC clients happily registered as SCCP phones with no issues whatsoever but the 7960G is testing my patience.
I have already had this phone work perfectly with CUCM10.5 as SIP phone so not sure why its playing hard to get with CME8.6
I have tried both cmterm-7940-7960-8.12.00-sip.cop and cmterm-7940-7960-8.12.00-sip.cop.sgn as the image file but firmware status screen on the phone still shows P0S3-08-6-00.
Also the phone is not registering and shows as unprovisioned.
Status messages are W310 , W362, and W320: first and last are error parsing default and SIPxxxxxxxxxxxx.cnf files while the middle is "No Valid Line Names Provisioned"
debugging shows the following repeatedly:
May 5 11:35:56.750: TFTP: Looking for SIP0015C6A7FCF6.cnf
May 5 11:35:56.754: TFTP: Opened flash:/SIP0015C6A7FCF6.cnf, fd 0, size 1314 for process 398
May 5 11:35:56.766: TFTP: Finished flash:/SIP0015C6A7FCF6.cnf, time 00:00:00 for process 398
the config is as follows:
voice service voip
ip address trusted list
ipv4 10.0.0.0 255.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 10.0.125.254 port 5060
max-dn 5
max-pool 5
load 7960-7940 cmterm-7940-7960-8.12.00-sip.cop
timezone 31
hold-alert
tftp-path flash:
file text
create profile sync 0305432048555033
voice register dn 1
number 2005
name Bashar Makki
shared-line
label Bashar
voice register pool 1
id mac 0015.C6A7.FCF6
type 7960
number 1 dn 1
username Bashar password 1234
tftp-server flash:cmterm-7940-7960-8.12.00-sip.cop alias cmterm-7940-7960-8.12.00-sip.cop
control-plane
mgcp profile default
telephony-service
no auto-reg-ephone
max-ephones 5
max-dn 5
ip source-address 10.0.125.254 port 2000
cnf-file location flash:
load 7960-7940 CME/cmterm-794060-sccp.tar
time-zone 31
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name talal secret 5 $1$xN1Q$/mQwQWSRstTDBWlt58sS1.
web admin customer name Customer password customer
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 May 05 2017 10:37:49
Now, the SIP files are from Cisco website so I know they work.
Where am I going wrong?
DNS, DHCP, NTP and everything is working since the two CIPC clients work perfectly and show the right time and date.
PS. I am studying for CICD exam
05-08-2017 02:31 AM
Hi Talal,
can you check whether the phone has an ITL file as you have registered with CUCM 10.X and if yes, then delete it and try.
https://www.variphy.com/kb/delete-itl-file-on-cisco-7945-or-7965-ip-phone
Rajan
