8900 series phones
tkavithas87
Which CME version supports 8900 series video ip phones?
thanks
kavi
Hi Kavi,
Here is the data sheet for the 8961 IP Phone:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10451/ps10511/data_sheet_c78-565397.html
It supports SIP protocol only for signaling and H.264 for video. It also clearly states that this model is supported on
CME 8.6 or later.
Since this model supports only SIP protocol, you would not see the type 8961 as an available option under ephone nor will you find the load 8961 option under telephony-service. If you configure the following, you would be able to see load 8961 as an option:
R2(config)#voice register global
R2(config-register-global)#
R2(config-register-global)#mode cme
R2(config-register-global)#load ?
  3911       Select the firmware load file for 3911
  3951       Select the firmware load file for 3951
  7905       Select the firmware load file for 7905
  7906       Select the firmware load file for TNP 7906 phone
  7911       Select the firmware load file for TNP 7911 phone
  7912       Select the firmware load file for 7912
  7941       Select the firmware load file for TNP 7941 phones
  7941GE     Select the firmware load file for TNP 7941GE phones
  7942       Select the firmware load file for TNP 7942 phones
  7945       Select the firmware load file for TNP 7945 phones
  7960-7940  Select the firmware load file for Telecaster 7960 & 7940 phones
  7961       Select the firmware load file for TNP 7961 phones
  7961GE     Select the firmware load file for TNP 7961GE phones
  7962       Select the firmware load file for TNP 7962 phones
  7965       Select the firmware load file for TNP 7965 phones
  7970       Select the firmware load file for TNP 7970 phones
  7971       Select the firmware load file for TNP 7971 phones
  7975       Select the firmware load file for TNP 7975 phones
  8961       Select the firmware load file for RT 8961 phones
  9951       Select the firmware load file for RT 9951 phones
  9971       Select the firmware load file for RT 9971 phones
  ATA        Select the firmware load file for ATA
Here is a general doc which talks about configuring CME for SIP protocol:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f33eb.shtml
HTH.
Harmit.
9 Replies 9
kevinmpotts
I know that 8.6 does if that helps you out.
WE have the CME version 8.6.but It doesnt support.
Jaime Valencia
Just search cco for cme compatibility and you'll get the compatibility tables which have such info
java
if this helps, please rate
I found the supported phone models using the following link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme88spc.html
In this document says CME 8.6 suppots phone 8961.but It doesnt support for the CME I have.What could be the reason?any licenses need to install?
2921#show tel
2921#show telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_serie        s_home.html
protocol mode default
ip source-address 192.168.254.240 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 2
max-dn 10
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
2921(config)#ephone 1
2921(config-ephone)#typ
2921(config-ephone)#type ?
  12SP    12SP+ and 30VIP phones
  6901    Cisco IP Phone 6901
  6911    Cisco IP Phone 6911
  6921    Cisco IP Phone 6921
  6941    Cisco IP Phone 6941
  6961    Cisco IP Phone 6961
  7902    Cisco IP Phone 7902
  7905    Cisco IP Phone 7905
  7906    Cisco IP Phone 7906
  7910    Cisco IP Phone 7910
  7911    Cisco IP Phone 7911
  7912    Cisco IP Phone 7912
  7920    Cisco IP Phone 7920
  7921    Cisco IP Phone 7921
  7925    Cisco IP Phone 7925
  7926    Cisco IP Phone 7926
  7931    Cisco IP Phone 7931
  7935    Cisco IP Conference Station 7935
  7936    Cisco IP Phone 7936
  7937    Cisco IP Conference Station 7937
  7940    Cisco IP Phone 7940
  7941    Cisco IP Phone 7941
  7941GE  Cisco IP Phone 7941GE
  7942    Cisco IP Phone 7942
  7945    Cisco IP Phone 7945
  7960    Cisco IP Phone 7960
  7961    Cisco IP Phone 7961
  7961GE  Cisco IP Phone 7961GE
  7962    Cisco IP Phone 7962
  7965    Cisco IP Phone 7965
  7970    Cisco IP Phone 7970
  7971    Cisco IP Phone 7971
  7975    Cisco IP Phone 7975
  7985    Cisco IP Phone 7985
  CIPC    Cisco IP Communicator
  IP-STE  SCCP IP STE
  anl     SCCP Gateway (AN)
  ata     ATA  phone emulation for analog phone
  bri     SCCP Gateway (BR)
thanks
kavi
Hi Kavi,
Happy New Year!
Can you please post the show version output from this CME?
Harmit.
Thanks Harmit,
Wish you the same.
Following is the show version output
2921#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, REL        EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
2921 uptime is 2 days, 21 hours, 16 minutes
System returned to ROM by reload at 16:43:21 sg Mon Dec 31 2012
System restarted at 16:44:41 sg Mon Dec 31 2012
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL1636147P
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FGL1636147P
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Evaluation     securityk9
uc            uck9          Evaluation     uck9
data          None          None           None
Hi Kavi,
CME 8.6 or later.
HTH.
Harmit.
Thanks Harmit.
Anytime my friend :-)
Harmit.
