12-26-2012 04:30 AM - edited 03-16-2019 02:52 PM
Hi all,
I have a third party solution for recording calls, (SIP Trunking and BIB enabled in phones) but when I try recording a device type 8945, only audio is send to Recording Server.
Somebody knows how is H.264 is sent to Recording Server or how its works in recording environment in a CUCM topology !! I´m search all cisco documentations and ready all Features and Services guides, but nothing about H.264 !!!
Thanks and regards.
12-26-2012 05:03 AM
Hi Guilherme,
AFAIK, video recording is not possible at this time and is on the roadmap (CUCM 9.5 tentatively).
HTH.
Harmit.
12-26-2012 08:19 AM
Hi Harmit,
Thanks for your reply.
Do you know if have another method to do this video recording? Something like Cisco MediaSense or another third party application approved by Cisco ?
Thanks and Regards.
12-26-2012 08:27 AM
Hi Guiherme,
Yes, mediasense can do this as per SRND:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/contactc.html#wp1082700
Though I've never tested how it works, it appears it should do the trick for video recording.
HTH.
Harmit.
