9841-DP MPP: accurate XML reference guide?
cscodisco
Hi,  I am trying to harden a Cisco 9841-DP MPP phone running Phone OS 3.4.1.   In particular I need to prevent users from accessing the ‘Settings’ configuration menus.
I was looking for an XML reference guide that was accurate for the 9841-DP, but couldn’t locate one on the 9841 portal.
I have tried the following parameters in the XML configuration file, but as you can see from the DEBUG log, they are not accepted on the 9841.
voice-fapp-xml tag ignored, Device_Administration,
voice-fapp-xml tag ignored, LCD_Admin_Menu_Enable,
voice-fapp-xml tag ignored, Require_Authentication_for_LCD_Menu_Access,
voice-fapp-xml tag ignored, Network_Configuration,
voice-fapp-xml tag ignored, Provisioning_Settings,
voice-fapp-xml tag ignored, Phone-UI-User-Mode,
voice-fapp-xml tag ignored, RestartPhone,
voice-fapp-xml tag ignored, Debug_Server
Is there an XML reference guide for the 9841?
Is it possible to restrict access to the Settings menu?
0 Replies 0
