08-10-2017 05:25 AM - edited 03-18-2019 12:20 PM
I am trying to setup a new subscriber node on a virtual machine, but i have a problem.
First of all i tried to add this node by following steps : system>server>add new>CUCM Voice/Video, but when i click save button, error message "Add failed. TypeDbErrors.IM_PRESENCE_APPSERVER_EXISTS" shows up. I have a presence server(only pub) but it is not associated with CUCM so there is nothing to delete in CUCM about it. ( And i also shutted down presence server which is located in a virtual machine too)
Meanwhile i started to set the subscriber up but i can't pass the section "Connectivity to First Node". It says, " this node is not found in XXX's server configuration, is this node configured on XXX? Is XXX the correct first node for this node?" so i am stucked. Does anyone has idea about it?
Solved! Go to Solution.
08-11-2017 01:46 AM
Go to System -> Application and remove everything and then try.
(Rate if it helps)
JB
08-10-2017 06:24 AM
What version is this?
08-10-2017 06:56 AM
System version: 10.5.1.11901-1
08-10-2017 07:56 AM
Can you attach output for below.
run sql ccm select * from AppServer
show network cluster
JB
08-10-2017 10:43 PM
admin:show network cluster
10.1.24.5 CM-SUB2 Subscriber callmanager DBSub authenticated using TCP since Tue Apr 25 22:31:07 2017
10.6.30.10 CM-SARAC Subscriber callmanager DBSub authenticated using TCP since Thu Jul 27 20:03:29 2017
10.1.24.6 CUP-AKM.ibb.gov.tr CUP-AKM Subscriber unknown unknown not authentica ted - INITIATOR since Fri Jan 13 11:33:47 2017
10.6.30.6 CUP-SARAC Subscriber cups DBSub not authenticated - INITIATOR since Wed May 10 18:55:01 2017
10.1.24.2 CM-PUB Publisher callmanager DBPub authenticated
admin:run sql ccm select * from appserver
pkid name tkappserver ipaddr administrationurl enduserurl fkprocessnode
11469d13-08aa-4f3d-9480-c357029a6a03 10.1.24.6 3 NULL
5c629d09-3ff8-8295-8772-7de319c317ac 10.6.30.6 3 NULL
08-10-2017 10:43 PM
Can you also provide output for
JB
08-10-2017 10:53 PM
08-10-2017 11:01 PM
Are you trying to ass IM&P Subscriber or CUCM Subscriber?
JB
08-11-2017 01:36 AM
I am trying to add CUCM Subscriber not IM&P Subscriber.
08-11-2017 01:46 AM
(Rate if it helps)
JB
08-11-2017 01:54 AM
Thank you for your concern. Now i can add subscriber.
08-11-2017 02:12 AM
happy to help
Thanks for updating the post.
JB
10-26-2018 03:56 AM
I have the same problem but with IMP sub you can help me please
