Adding SIP trunk to CUCM problem
Samer R. Saleem
Level 4
Level 4
i have SIEMENS system connecting to CUCM by trunk, i have added one trunk successfully
but when i try to add a second one i get this error, how can i add more trunks to the SIEMENS system without this error?
2 Accepted Solutions
You do not need a different SIP trunk for every range, I'm gonna take a wild guess, but you associated the SIP trunk directly to the RP, and that's why you want another one?
if so, just use route groups/route lists.
java
if this helps, please rate
you can use Route Pattern like [3-5]XXX to match all the extensions and use single Trunk if this is what you want.
MOHIT SINGH
Your existing SIP trunk in CUCM is configured for destination IP 10.211.1.40 (Siemens) and source IP of CUCM and source port 5060.
Why are you creating SIP trunk with same information?
10.211.1.40 is the SIEMENS system and i need to add mode extension ranges for example i added 4xxx range, and i want to add 5xxx and 3xxx
java
