IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5673 Views
  • 14 replies
After recently completing an installation of a CME in South Africa connecting to 3 x TELKOM BRI lines for PSTN access, I found very little helpful information online so I'm going to submit my findings. I had several issues getting LAYER 1 up and runn...
c30050814 by Level 1
  • 647 Views
  • 4 replies
We are using CUCM version 11.5.1.12900-21, getting & RTMT alert about "LogPartitionLowWaterMarkExceed " attached is the snap shot for the same ...how do we resolve this issue so that stopped getting & RTMT alerts... is there any cisco documents to re...
I have small lap ( router, switch , 2 phone 7960s and 7970 and UCS220 (vm)) this is my router settingRouter #show running-configBuilding configuration...Current configuration : 1500 bytes!version 12.4service timestamps debug datetime msecservice time...
Greeting SIP Experts,I am testing SIP Trunking and having some issues with outboud calls.  I get a fastbusy after dialing the called number. Please find attached CUCM version 10.5ISR 4431 with IOS Version 15.4(3)S4Calling Number: 6132604849Called Num...
mightyking by Level 6
  • 4805 Views
  • 18 replies
I'm using CUCM 9.1.2 and am sending external calls via a CUBE through a SIP trunk to our carrier.  All normals calls are sent with a + but any call forwarded calls are sent with ++.  Below is an example calling number 1-111-111-1111 (from outside) ca...
JSang1234 by Level 1
  • 508 Views
  • 1 replies
Unanswered Topics
