Any way of configuring a phone to go back to its main screen after a certain amount of idle time?
Michael Marzol
We have a mix of 7900 series phones. We'd like to be able to have the phones return to the main screen after a specified amount of time. For example, once you get deep into a couple of submenus or just checking your placed or missed calls, it'd be nice for the phone to automatically return to the main screen after a certain amount of idle time rather than having to hit the 'exit' or 'cancel' soft keys a bunch of times just to get back to it. Any suggestions or possible answers would be greatly appreciated.
Thanks In Advance,
-Mike
William Bell
Mike,
Well, there is an idle URL that you could use but that may not be what you are looking for. The idle URL points the phone to a XML application and can do things like display a stock ticker or some such nonsense. I suppose you could be a bogus URL that would cause the phone to "error" out. Or have the XML app do nothing.
The idle URL has a timer associated with it as well. Not the most graceful solution, but aesthetically it gets you close to what you are looking for.
HTH.
Regards,Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks for the prompt response, Bill.
Using the solution you mention, wouldn't the phone try to pull that 'dummy' XML file even when it is idle under the main screen? I would want the phone to only idle out after a user goes idle after going into any one of the menus from the main screen.
-Mike
Correct. That would be one of the trade-offs for the work around.
Bill
