01-02-2013 06:49 AM - edited 03-16-2019 02:57 PM
Hi All,
I'm having trouble registering my ATA 187 in 9.1. I've attached my config, ccsip debug, and a screenshot of the ata webpage. I'm seeing a lot of SIP 401 unauthorized messages and the ATA looks to have the DN's, but won't register. Any ideas?
Also notice I ended up creating a 2nd pool with the mac address A84E.A608.8D01 because I saw in the status messages that the ATA187 was looking for "
File Not Found : CTLSEPA84EA6088D01.tlv "
01-06-2013 05:05 PM
Samuel,
Can you try altering the TFTP server line
in your sip register config
voice register global
mode cme
source-address 192.168.100.1 port 2000
This will put the line back to its default.
See if that allows the phone to register
Alex.
Please rate useful posts.
01-07-2013 05:43 AM
As you can see from below, port 5060 is the default for SIP
"UCS-2901-MD(config)#voice register global
UCS-2901-MD(config-register-global)#sou
UCS-2901-MD(config-register-global)#source-address 192.168.100.1 port ?
<2000-9999> Specify the port: 2000 - 9999, default 5060 <------------- 5060 is default for SIP
I'll give it a shot, but I've used port 5060 for other SIP installs. Any other suggestions?
01-08-2013 05:40 AM
I finally got the ATA187 to register. I added "authenicate register" and "authenticate realm all" to voice register global and this seemed to fix it
01-08-2013 10:41 AM
Samuel,
Well Done +5 to you
Alex.
03-03-2013 02:07 AM
Hey just to add in between kindly please advise if CME 9.0 supports auto-configuration for SIP phones.
Unni
03-07-2014 09:57 AM
Hello Friends,
I have a similar issue, because the ATA don´t register.. the device try to locate the files but don´t find anything.. can any help me please.
debug ccsip messages => Return nothing.
debug tftp events => Returns This:
Mar 7 17:53:38.891: TFTP: Looking for CTLSEP255C425C4901.tlv
Mar 7 17:53:39.111: TFTP: Looking for ATA255C425C4901.cnf.xml
Mar 7 17:53:39.331: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:39.331: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:39.339: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
Mar 7 17:53:41.627: TFTP: Looking for CTLSEPC0255C425C49.tlv
Mar 7 17:53:41.855: TFTP: Looking for ATAC0255C425C49.cnf.xml
Mar 7 17:53:42.071: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:42.071: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:42.079: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
Mar 7 17:53:44.371: TFTP: Looking for CTLSEP255C425C4901.tlv
Mar 7 17:53:44.591: TFTP: Looking for ATA255C425C4901.cnf.xml
Mar 7 17:53:44.803: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:44.803: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:44.811: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
Mar 7 17:53:47.107: TFTP: Looking for CTLSEPC0255C425C49.tlv
Mar 7 17:53:47.335: TFTP: Looking for ATAC0255C425C49.cnf.xml
Mar 7 17:53:47.551: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:47.551: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:47.559: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
Mar 7 17:53:49.847: TFTP: Looking for CTLSEP255C425C4901.tlv
Mar 7 17:53:50.075: TFTP: Looking for ATA255C425C4901.cnf.xml
Mar 7 17:53:50.291: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:50.291: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:50.303: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
Mar 7 17:53:52.607: TFTP: Looking for CTLSEPC0255C425C49.tlv
Mar 7 17:53:52.831: TFTP: Looking for ATAC0255C425C49.cnf.xml
Mar 7 17:53:53.051: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:53.051: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:53.063: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
Mar 7 17:53:55.359: TFTP: Looking for CTLSEP255C425C4901.tlv
Mar 7 17:53:55.583: TFTP: Looking for ATA255C425C4901.cnf.xml
Mar 7 17:53:55.787: TFTP: Looking for XMLDefault.cnf.xml
Mar 7 17:53:55.787: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 14, size 3453 for process 272
Mar 7 17:53:55.803: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 272
and repeat the same every time.
This is the configuration if ATA in CME 9.1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
registrar server
mode cme
source-address 161.193.170.2 port 2000 (I changed the port to 5060, but the same problem)
max-dn 300
max-pool 300
authenticate register
tftp-path flash:
file text
create profile sync 0006591301372285
network-locale ES
user-locale ES
voice register dn 171
number 3000
name ATA
label ATA
voice register pool 171
id mac 255C.425C.4901
type ATA-187
number 1 dn 171
Thanks..
