04-14-2013 01:45 PM - edited 03-16-2019 04:47 PM
I have configured a ATA 187 with an ext 6666 and it is registered with CM, after some time my plan change and change the EXT to 6868, Now the ATA is not registering. I tried to delete ATA and add agian but same results not registered,
Can anybody can give any hints.
Solved! Go to Solution.
04-25-2013 03:52 AM
hello clark
good that the problem is solved , i just told you if you have a problem for ATA registeration
1- before you add the ATA to your network , add it to your call manager as a configuration only .
2-after you configure MAC and DN successfully for ATA.
3- Attach ATA to your network ,then test registeration.
thank you
please rate if this will help
04-14-2013 02:36 PM
Hello
please share the firmware of your ATA , CUCM version.
Try to disconnect ATA 187 from your network and add ATA 187 on you CUCM successfully , after that add ATA 187 as a hardware , then test registeration.
thank you
04-25-2013 03:45 AM
Hello Islam,
I was doing a mistake, without deleting the directory i was adding a same MAC to another extension that the reason it was accepting the same previous extension.
I didnt understood your previous reply can you help me to understand
after that add ATA 187 as a hardware ?????
04-25-2013 03:52 AM
hello clark
thank you
