05-27-2009 03:48 AM - edited 03-18-2019 10:22 AM
I am using CCM 4.1(3). I have 2 auto attendant console clients running cluster wide. Both were working fine but today one of the client is keep giving problem. While trying to run the client it says "connecting to server" and stays there forever while the other client is working fine.. I tried to uninstall and reinstall but didnt work.. Did device reassociation as well but didnt work... Any help please ?
Sheeraz
Solved! Go to Solution.
05-27-2009 06:13 AM
Try restarting the TCD service
java
if this helps, please rate
05-27-2009 06:13 AM
java
