04-17-2008 02:46 AM - edited 03-15-2019 10:07 AM
Hi Guys,
I have location based CAC configured on our cluster of CCM's (4.1)and is used for small multiple remote sites dialling internally, these sites are restricted to a specific number per site depending on their Circuit size, all remote sites using g729.
However I was wondering if an internal on-net call is placed from a remote site and didn't actually suceed due to CAC, is there any log files that I could view this in?
Thanks in advance
Paul
04-17-2008 07:38 AM
unfortunately there are no CAC logs on which you can see that information.
the only place where that info shows up is in the CUCM traces
javalenc
if this helps, please rate
04-17-2008 09:45 AM
Apart from CCM traces you need to enable Location traces under CallManager Service Parameters
04-17-2008 12:20 PM
cheers guys, tks alot for the info, i'll enable the traces and then check them out...
Tks for the help
Paul
