Called Party Transformations
nestor.gallego1
Hi guys; I could help with the following:
For calls to the PSTN, dial the prefix 9xxxxxxx. the operator should receive only 7 digits.
I need to delete the prefix 9 when the call leaves the CUCM toward the operator. I see exisite the option to do so in the "Called Party Transformations" but does not appear enabled, you need to do to enable this option ??
Imagen
Vivek Batra
You need to configure pattern with dot like 9.xxxxxxx and now if you set discard digit to PreDot, all/any digits before dot will get stripped off.
- Vivek
Vivek Batra
- Vivek
