CallManager 8.0 disable http only https
Jason Aarons
Level 10
Level 10
Customer’s info security group wants to know if Tomcat’s http can be disabled, only want CCMAdmin to listen for https.  Currently is listens on 80 and redirects to the secure side.
Hi Jason,
They way I see it this is not possible. As you said the callmanager actually listens to port 80 and then forwards everything to 8080.
If you block the port 80 then you would not be able to send any traffic to cucm. I believe this requires tweaking and it will no longer be a supported platform from TAC perspective.
That's my opinion if I understood correctly.
Christos
