calls coming from CCM to ccme Fwd to VM cue not working
sdeltoro1
Hi Everybody knows what is missing?
I made a call direct from ccm to vm(cue) on ccme and work perfect indeed using trancoder. and I have probed the trasncoding between to sides adding transcoder on ccme and work fine.
gogasca
Level 10
Level 10
I assume allow connecttions h323 to sip is configured
Also try call-forward pattern .T in Telephony-service and transfer-pattern .T in telephony service
gogasca
Level 10
Level 10
thank you. I was missing the call-forward.
everithing is o.k I just a have similar issue. but the call-fwd doesn't work when the call is coming from ccm via ipipgw(ccm h323 to ipip and sip to ccme) the direct call work fine but when the ccme have cwd to a another ccme ext the call fail.
thanks
