08-10-2017 10:33 AM - edited 03-18-2019 12:20 PM
Hi Experts,
I have Cisco ISR4321, CUCME v11.0, with 1 E1 controller, and 2FXS/4FXO Ports.
All my SIP Phones works perfectly, and the Analog Phone for FXS Port can call the Local IP Phones, and receive the calls from local and the PSTN
but, it can't make call to the Outside using DID (E1)
I checked the debug voice ccapi inout command, I found that the Analog Phone use the dial-peer voip for CME, that is it take the first 4 digits from the external number (ex : called number : 0661XXXXXXXX => 0661), how can I enforce it to use the E1 (DID) for PSTN
how can I configure dial-peer pots for this ?
you find below the Important configuration for our Router :
voice-port 0/2/0
timeouts ringing infinity
description ## FAX 1 ##
station-id name Fax1
station-id number 0001 ==> Analog Phone Number
caller-id enable
dial-peer voice 1 pots
description ## To FAX #
destination-pattern 0001
port 0/2/0
dial-peer voice 10 voip
description ## Les appels entrant depuis l'exterieur ##
destination-pattern 0.... ===> Local Numbers
progress_ind setup enable 3
session target ipv4:X.X.X.X ==> IP @ of CME
voice-class codec 100
dtmf-relay rtp-nte
no vad
dial-peer voice 123 pots
destination-pattern 05........ ==> to External Number
progress_ind alert enable 8
no digit-strip
direct-inward-dial
port 0/1/0:15
forward-digits all
Any Suggestions
Thank you, Youssef.
08-10-2017 11:25 PM
Hi Youssef,
please share the debug logs and calling/called details as i can't see any dial peer that is matching your details of called number.
08-10-2017 11:55 PM
Hi Yousef,
dialpeer 10 is matched because its the 1st match when cme starts call routing. Dialpeer 10 (0...) will immediately match 0661 and ingore the reset digits (assuming that phones are using kpml which is most likely the case).
To overcome the problem modify you local dp 10 to match the range of local extensions. For example if your extension range is 8xx then dp 10 should be 08...
Then configure proper dial peer for e1 calls as you dont have one to match 06.......
Good practice is used access codes when it comes to dial outside and you strip on the dial peer. For example users can dial 906613456765 where 9 is access code and then you strip it on outside dp. This access code shouldn't be used for local calls.
08-14-2017 04:52 PM
Hi Mohammed,
thank you for your reply.
I added the second digit on the DP 10 voip (destination-petern 00..) and now work perfectly.
but I have another problem :
I created 4 groups, 1- Local calls, 2- National Phones, 3-for National Mobiles, 4-for International Calls
I would like to configure and assign FXS ports in the International Calls group, how can I configure this?
thank you.
youssef.
