04-17-2013 02:02 AM - edited 03-16-2019 04:50 PM
I'm trying to implement forwarding calls from cisco ephones to mobile phones if the employee is not answering on his stationary phone.
On a ephone-dn i write:
call-forward noan [any number here] timeout 8
When I'm trying to make a call to the stationary phone, after 8 seconds it just stops ringing and says "missed calls: 1", but I continue hearing the dialing tone as if the stationary phone kept ringing.
I tried different target numbers - cellphone numbers, internal extension numbers - everytime it's the same.
Calling these numbers works, but forwarding to these numbers doesn't work: i keep hearing dialing tones forever.
If you need any debugs or configs i'll post them.
(If i remove the call-forward pattern, i just hear the busy tone)
telephony-service
no auto-reg-ephone
max-ephones 12
max-dn 30
ip source-address 192.168.66.129 port 2000
system message -=TransBank=-
cnf-file location flash:
cnf-file perphone
time-zone 35
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern ....
call-forward pattern .T
moh "flash0:/phones/music-on-hold.au"
multicast moh 239.1.1.1 port 2000
transfer-system full-consult
transfer-pattern ....
dial-peer voice 1 voip
session target ipv4:10.1.200.57
destination e164-pattern-map 1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
softkeys idle Newcall Redial Gpickup Pickup
softkeys seized Endcall Redial
voice class e164-pattern-map 1
description "Moscow city & mobile numbers"
e164 98800.......
e164 9849[5,8,9].......
e164 989.........
e164 64[^3].
e164 1....
e164 [2-6]...
ephone-dn 1
number 6430
label 6430
name 6430
call-forward noan 989160151539 timeout 3
ephone 1
device-security-mode none
mac-address 001F.CA35.1F2E
type 7911
button 1:1
04-17-2013 03:01 AM
Hi Nikolay.
Try to add a transfer-pattern .T and see if it works.
Carlo
Please rate all helpful posts
04-17-2013 04:24 AM
Thanks for the tip, but it didn't solve the issue.
What I have just found out is that if we call from a cisco ephone to the stationary cisco ephone the call transfer succeeds, but if we call from an Avaya phone to the stationary cisco ephone the call transfer fails and i keep hearing the dialing tones.
So the call transfer fails because Cisco equipment and Avaya equipment currently don't interoperate correctly.
Are there any CME settings we should look into to make them work together to forward "noan" calls?
10.1.200.57 is the SIP proxy.
It's CME too.
Currently I don't know how Avaya interoperates with CME (another employee is administering Avaya).
I guess it's some kind of SIP thing.
I'll contact him, maybe he has some ideas.
04-17-2013 06:13 AM
We managed to resolve the issue.
The missing configuration was:
supplementary-service h450.12
Now forwarding between CME and Avaya works.
The case is resolved.
