02-26-2016 06:50 PM - edited 03-17-2019 06:02 AM
Dear All, The gateway is mgcp. The phone behind it has number 4082022002. When making a call at 2002 and 2022002, the phone can get a bell voice. but if making a call at 4082022002, the phone cannot get voice, but I can get it debug message as below. Any one can help to take a look. Thank you
*Feb 27 03:04:31.853: ISDN Se0/1/1:23 Q931: Applying typeplan for sw-type 0xD is 0x4 0x1, Calling num 5252222
*Feb 27 03:04:31.853: ISDN Se0/1/1:23 Q931: Sending SETUP callref = 0x00D5 callID = 0x8059 switch = primary-ni interface = Network
*Feb 27 03:04:31.853: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8 callref = 0x00D5
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Display i = '5252222'
Calling Party Number i = 0x4181, '5252222'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xA1, '4082022002'
Plan:ISDN, Type:National
*Feb 27 03:04:31.893: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80D5
*Feb 27 03:04:31.901: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0088
Standard = CCITT
Channel ID i = 0xA98382
Exclusive, Channel 2
*Feb 27 03:04:31.901: ISDN Se0/1/1:23 Q931: Received SETUP callref = 0x8088 callID = 0x0009 switch = primary-ni interface = Network
*Feb 27 03:04:31.921: ISDN Se0/1/1:23 Q931: Applying typeplan for sw-type 0xD is 0x4 0x1, Calling num 5252222
*Feb 27 03:04:31.921: ISDN Se0/1/1:23 Q931: Sending SETUP callref = 0x00D6 callID = 0x805A switch = primary-ni interface = Network
*Feb 27 03:04:31.925: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8088
*Feb 27 03:04:31.925: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8 callref = 0x00D6
Standard = CCITT
Channel ID i = 0xA98383
Exclusive, Channel 3
*Feb 27 03:04:31.961: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80D6
*Feb 27 03:04:31.969: ISDN Se0/1/1:23 Q931: RX <- SETUP pd = 8 callref = 0x0089
Standard = CCITT
Channel ID i = 0xA98384
Exclusive, Channel 4
*Feb 27 03:04:31.969: ISDN Se0/1/1:23 Q931: Received SETUP callref = 0x8089 callID = 0x000A switch = primary-ni interface = Network
*Feb 27 03:04:31.989: ISDN Se0/1/1:23 Q931: Applying typeplan for sw-type 0xD is 0x4 0x1, Calling num 5252222
*Feb 27 03:04:31.989: ISDN Se0/1/1:23 **ERROR**: CCPMSG_OutCall: fails with cause 0x22
*Feb 27 03:04:31.993: ISDN Se0/1/1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8089
*Feb 27 03:04:32.001: %ISDN-6-DISCONNECT: Interface Serial0/1/1:3 disconnected from unknown , call lasted 0 seconds
*Feb 27 03:04:32.005: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8089
Cause i = 0x82A2 - No circuit/channel available
*Feb 27 03:04:32.025: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0089
*Feb 27 03:04:32.029: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8089
*Feb 27 03:04:32.049: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x80D6
Cause i = 0x80A2 - No circuit/channel available
*Feb 27 03:04:32.053: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x00D6
*Feb 27 03:04:32.061: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80D6
*Feb 27 03:04:32.073: %ISDN-6-DISCONNECT: Interface Serial0/1/1:1 disconnected from unknown , call lasted 0 seconds
*Feb 27 03:04:32.073: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8088
*Feb 27 03:04:32.085: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0088
*Feb 27 03:04:32.089: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8088
*Feb 27 03:04:32.105: ISDN Se0/1/1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x80D5
*Feb 27 03:04:32.109: ISDN Se0/1/1:23 Q931: TX -> RELEASE pd = 8 callref = 0x00D5
*Feb 27 03:04:32.121: ISDN Se0/1/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80D5
02-26-2016 10:53 PM
From the logs I can see that both 5252222 and 4082022002 are hosted at same site. But looks that the calling number css can't see the partition of called numbers. Hence the call is going out to telco and looped back to your gateway.
Relook at your css/pt config and make sure that they can dial within cucm without going out to pstn.
Simply create a translation pattern for 4082022002 which convert it to 2002 and make it pt accessible by 5252222 css
02-27-2016 09:43 AM
Thank you so much. Translation was wrong. now it works out
