06-29-2010 02:48 AM - edited 03-15-2019 11:28 PM
Hi All,
I have IP Telephony setup with CCME 7.0 and SIP trunk and I am getting the error as “Cannot complete conference.” When I am trying to make conference with the PSTN Numbers.
The sip dial peer used G729rb8 codec as per the ISP standard. As per my knowledge that conference feature doesn’t support G729 codec. Is it possible to do transcoding for the calls coming from the SIP dial peer leg , on the same CME itself without putting transcoder (router as a transcoder ) between the ISP and CME in the customer Local area network .
Please suggest
Nayeem
06-29-2010 05:48 AM
Have you already tried to make conference with g711?
Can you give the running config
1/ In the DSP farm
2/ In the telephony-Service
06-29-2010 07:29 AM
If your going to use DSPs you could configure a HW CFB or XCODER
Transcoding compresses and decompresses voice streams to match endpoint-device capabilities. Transcoding is required when an incoming voice stream is digitized and compressed (by means of a codec) to save bandwidth, and the local device does not support that type of compression.
Cisco CME 3.2 and later versions support transcoding between G.711 and G.729 codecs for the following features:
•Ad hoc conferencing—One or more remote conferencing parties uses G.729.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrnsc.html
The "Configuring conferencing" has the instructions for HW CFB.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
