Hi Experts,
I have CME with IOS version 15.5, E1, 2FXS Ports and 4 FXO Ports, and I configured all IP Phones by SIP protocole, I linked my Analog phone to FXS Port, the call from SIP Phone and cellphone work fine, but the call from Analog Phone to SIP Phone and Cellphone doesn't work,
I'll to configure the FXS ports as Fax, using E1 DID.
you find below my config service voip and dial peer :
voice service voip
media disable-detailed-stats
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
sip
bind control source-interface GigabitEthernet0/0/1.30
bind media source-interface GigabitEthernet0/0/1.30
registrar server expires max 3600 min 1800
telephony-service
max-conferences 8 gain -6
web admin system name youssef password 123456
dn-webedit
time-webedit
transfer-digit-collect orig-call
transfer-system full-consult
dial-peer voice 1 pots
description ## To Fax ##
service fax_hop_on
destination-pattern 0001
progress_ind setup enable 3
progress_ind alert enable 8
no digit-strip
direct-inward-dial
port 0/2/0
forward-digits all
dial-peer voice 10 voip
description ## Call from External ##
destination-pattern 0...
session target ipv4:10.10.30.254 ==> the IP address of CME
voice-class codec 100
dtmf-relay h245-alphanumeric
dial-peer voice 4 pots
description ## Call vers External ##
destination-pattern 0[5-8]........
no digit-strip
direct-inward-dial
port 0/1/0:15
forward-digits all
Can you help me please ? thank you
Youssef.
