06-15-2016 03:04 AM - edited 03-17-2019 07:14 AM
Hi All,
We cannot make a outgoing call using the FXO ports of the Voice Gateway and we are getting a busy tone. Already checked the FXO lines and directly connected them to an analog phones and lines are confirmed working. Voice Gateway is currently registered to the CUCM as MGCP. During our testing and debugging of calls, we found a cause code of 34 and 47.
I attached the Show run config and also the logs from debug voice ccapi inout. Appreciate if you can help us. Upon checking the cause code 47, it is indicating resource unavailable or Internal resource allocation failure.
Thank you
06-15-2016 05:31 AM
can you share below debugs for a failed call
debug mgcp packet
debug voip ccapi inout
debug vpm signal
Collect above debugs together not separately.
06-15-2016 10:36 AM
You can try to register a transcoder and apply it to the MGCP GW to see that works.From error 47 it does sounds like codec mistmatch issue.
You can refer to below thread as where similar issue was resolved.
