CCM 7.x and Registered port on a VG224 (some ports not registering)
arthurbecker
Level 3
Level 3
I have a VG224 taht is registered with my Call Manager 7.x via SCCp. The issue that I have a total of 15 ports configured and 6 are not showing registered. They are in the same device pool are copies on each other except for the extensions used. What else can I look fot to see why they will not come up?
William Bell
Have you checked the configuration on the vg224 to ensure you have enabled the stcapp for the ports in question?
Also, what is the output of "show stcapp device summary"?  Please post.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
