CCM/SDL logs by RTMT
akram.root
Level 4
Level 4
Hello all,
I need your help.
I would like to collect logs CCM/SDL by RTMT for CUCM12.5 for last 5 hours  in RTMT , but i can't , it give me just for last 1 hour.
Could you help me for that?
Best regards
Akram
It depends on how fast the SDL log files are being filled. CUCM keeps 256
files and overwrite them once the last file is filled. If you aren't able
to get more than 1 hr worth of the logs, then your files are filled fast.
This depends on the logging level configured in your cluster, the type of
logs enabled, etc.
Either tweak your logging settings from serviceability console or send the
logs to remote logging server.
***** please remember to rate useful posts
thank you for your reply , how can i get it ?
