CCM5 Successful Recovery
gjosivljevic
Does anybody have done successful CCM5 system backup and restore procedure without errors?
I have problem with database replication on subscriber so I'm interested does anybody have the same problem.
6 Replies 6
Hi there,
taken from the Release Notes Document of Cisco the solution is:
Step 1 Stop the dbmon on all the subscriber servers.
admin:utils service stop Cisco Database Layer Monitor
Service Manager is running
Cisco Database Layer Monitor[STOPPING]
Component is not running
Cisco Database Layer Monitor[NOTRUNNIG]
admin:
admin:
admin:quit
Copyright Cisco Systems 2006
[root@nw096a-86 root]#
[root@nw096a-86 root]# ps -ef | grep dbmon
root 28142 27797 0 15:59 pts/0 00:00:00 grep dbmon
Step 2 After DRF restore on the publisher server completes, restart the dbmon service.
admin:utils service start Cisco Database Layer Monitor
Cisco Database Layer Monitor[STARTED]
admin:quit
[root@nw096a-86 sdi]# ps -ef | grep dbmon
database 28634 3362 4 16:11 ? 00:00:00 /usr/local/cm/bin/dbmon
root 28663 27797 0 16:12 pts/0 00:00:00 grep dbmon
Hope this helps.
Cheers.
Hi venias!
Problem is because I have new subscriber installation, subscriber is not active through publisher installation and restore procedure. After installing subscriber and importing I have problem with db replication on subscriber server.
Did you ever successful recovery pub/sub servers?
RGS
Hi gjosivljevic,
What is the exact version of CCM you have?
I have CCM 5.0.4.2000-1
Are you doing the recovery on the same piece of hardware? If you are doing the recovery on a different machine, the procedure doesn't work, simply because the license file points to a different MAC Address.
Hope this helped.
Cheers,
Yes Venias, I done on the same hardware.
