Centralized PLM
Siva chinap
Level 5
Level 5
Dear All,
I have 10 cluster across multiple location, i am planning to keep all the licenses Centralized . Is it possible?
5 Replies 5
Jitender Bhandari
Hi Siva,
thats is completely possible, you can have multiple clusters licenced by single CUCM either stand alone or go-resident does not matter.
(Rate if it helps)
JB
Hi Siva,
see below
Cisco Prime License Manager
Cisco Prime License Manager (Prime LM, formerly Cisco Enterprise License Manager) aligns with the Cisco Prime management suite of products. Cisco Prime LM supports multiple clusters and multiple versions of products, such as Cisco Unified CM versions 10. x and 11. x.
Cisco Prime LM currently supports the following Cisco Collaboration applications:
  • Cisco Unified CM
  • Cisco IM and Presence Service
  • Cisco Unity Connection
  • Cisco Business Edition 6000
  • Cisco Business Edition 7000
  • Cisco Emergency Responder
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/migratn.html?bookSearch=true
(Rate if it helps)
JB
Thanks Jitendar.
Thanks Jitendar.
Hi Siva, Happy to help.
Don't forget to mark the post as answered if you don't have further questions.
JB
