change the key function of a blf sd to sd on add on module
wiser0011
How to change the key function of a blf sd to sd on add on module, I want to change the function of a specific key (129) on a add on module from a BLF SD to a plain SD, is this possible and where to change the key function?
Jaime Valencia
You need to mention what you're working with (CUCM/CME) and version, and not just what you want to do, in order to get any assistance.
java
if this helps, please rate
wiser0011
Sorry for that, I am currently on 9.1 CUCM, I am also wondering why the programmed keys in "Add/Update Busy Lamp Field Speed Dials" drop down action is not showing up on the module (CP-CKEM-C), when viewing the device (9971) in the field on the left under "Association Information", "Modify Button Items, Add On Module(s) buttons 21 -114 show NONE, and the programmed buttons in Add/Update drop down list are in "Unassigned Associated Items" buttons 115 - 131, is this why the newly programmed buttons 115-131 are not showing in the module?
Thanks for any support or guidance provided.
Tom
