Change the System Message in CUCM 8.0
abraham_ngami
Is it possible to modify the defaut message "Your current options" that display on the IP phones with CUCM 8.0 ? I know that this is possible with CUCME (Call Manager Express) but I'd like to know if it's also possible with CUCM.
Jaime Valencia
No, it's not possible to change that message in CUCM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
