Changing Extension Mobility login time value
Stuart C
Can anyone tell me if changing this value is service impacting, for example, does it log everyone out?  Or does it just take effect in the background and only once people log out and back in?
Jaime Valencia
Does not logs out anyone and only works after they login again
java
if this helps, please rate
Jaime Valencia
java
Hi Jamie,
Yes exactly that.
