CIPC 8-6-6-0 Windows 10 compatiblity
ccg-collab1
Level 2
Level 2
Hi All,
Would just like to know if CIPC already compatible in windows 10? Upon installing the CIPC running windows 10, it gives me error (Kindly see attached pic) however we tried to install this on other machine running windows 10 and it is working properly. Thanks
Josh
Jitender Bhandari
It is supported see below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_6/Release_Notes.html#CIPC_RF_R0C9D2DD_00>
JB
Do you have right permissions for this users to install it? Seems that its failing at CDP driver installation.
Are you using the same installation file which you used for the working machine?
Hi Mohammed,
Yes we use the same installation file with the working windows 10 machine.
