cisco 7821 xml phonebook
Sindikat88
Hello!
Prompt how to realize the general book of LDAP or MYSQL on this device without CUCM?
At present when pressing the notebook button I have a Contacts Inquiry window, and occurs further nothing.
setup cisco:
<directoryURL>http://192.168.0.11/cisco/menu.xml</directoryURL>
server:
menu.xml:
<?xml     version="1.0"?>
<CiscoIPPhoneMenu>
  <Title>Asterisk Directory</Title>
  <MenuItem>
      <Name>Search person..</Name>
      <URL>http://192.168.0.11/cisco/menu2.xml</URL>
  </MenuItem>
</CiscoIPPhoneMenu>
menu2.xml:
<CiscoIPPhoneMenu>
  <MenuItem>
      <URL>http://192.168.0.11/cisco/search.php</URL>
  </MenuItem>
</CiscoIPPhoneMenu>
search.php:
<?php
header ("content-type: text/xml");
// Change here to match the webaddress absolute path
$URL = 'http://192.168.0.11/cisco/';
// Choose how many results to return if search term produces a lot of output
$per_page = '32';
// Change here to match your own passwords
$mysql_conn = mysql_connect('localhost', 'cisco', '*****');
// Dont change anything from here unless you know what you are doing
mysql_select_db('cisco', $mysql_conn );
$NAME=$_GET["sn"];
$page = $_GET['page'];
if ( ($page=='') )
   //check to see how many
   $result= mysql_query("SELECT count(users.name) as total
                         FROM users
                         WHERE users.name LIKE '%$NAME%' ", $mysql_conn);
   $howmany = mysql_fetch_row($result);
   if ($howmany[0] > $per_page)
      $start = 0;
      $index = 0;
      $total = $howmany[0];
      $remain = $per_page;
      print("\n");
      print("<CiscoIPPhoneDirectory>\n");
      print("<Title>Directorio FSM</Title>\n");
      print("<Prompt>Directorio FSM</Prompt>\n");
      print("<DirectoryEntry>\n");
      print("<Name>Num.coincidences > 32 </Name>\n");
      print("</DirectoryEntry>\n");
      while ($start < ($total + 1))
         print("<SoftKeyItem>\n");
         print("\t<Name>");
         print($index);
         print("</Name>\n");
         print("\t<URL>");
         print($URL."search.php?page=".$index."&amp;sn=".$NAME);
         print("</URL>\n");
         print("<Position>");
         print($index+1);
         print("</Position>");
         print("</SoftKeyItem>\n");
         $start = $start + $per_page;
         $index = $index+1;
      print("</CiscoIPPhoneDirectory>\n");
   } else {
      $result = mysql_query("SELECT name,extension,extension
                             FROM users
                             ORDER BY name ", $mysql_conn);
      print("\n");
      while($row = mysql_fetch_row($result))
         print("\t<Name>");
         print($row[0]."- ".$row[1] );
         print("</Name>\n");
         print("\t<Telephone>");
         print($row[2]);
         print("</Telephone>\n");
} else {
   $OFFSET = $page * $per_page;
   $sql = "SELECT name,extension,extension
           FROM users
           WHERE name LIKE '%$NAME%'
           ORDER BY name
           LIMIT $OFFSET, $per_page";
   $result = mysql_query($sql, $mysql_conn);
   print("\n");
      print("\t<Name>");
      print("</Name>\n");
      print($row[2]);
0 Replies 0
