Hi Guys,
I added one 7965 telephone on Call Manager Express. However, this phone could be called but the caller ID could not be displayed. Only this phone could not display caller ID. The number is 88300. Could anybody give me some suggestion? Thanks.
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
User Access Verification
Username:
Username: admin
Password:
% Password expiration warning.
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
Replace <myuser> and <mypassword> with the username and password you want to
use.
POCPBX01#sh running-Config
Building configuration...
Current configuration : 29400 bytes
! Last configuration change at 04:50:51 UTC Sun Nov 23 2014 by admin
! NVRAM config last updated at 04:50:59 UTC Sun Nov 23 2014 by admin
version 15.2
service password-encryption
hostname POCPBX01
boot-start-marker
boot system flash:c3900-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 5 $1$7bjg$/.aqb8thupRBPcowFFibj0
aaa new-model
aaa authentication login default local
aaa authentication login console none
aaa session-id common
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip multicast-routing
ip dhcp excluded-address 192.168.55.0 192.168.55.5
ip dhcp excluded-address 10.130.35.0 10.130.35.19
ip dhcp excluded-address 10.130.35.21 10.130.35.255
no ip domain lookup
ip domain name poc.com.au
ip host POCPBX01 10.130.35.10
ip cef
isdn switch-type primary-net5
trunk group PSTN
translation-profile incoming PSTN_Inbound_Prefixzero
translation-profile outgoing outgoingTP
crypto pki trustpoint TP-self-signed-3250545610
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3250545610
revocation-check none
rsakeypair TP-self-signed-3250545610
crypto pki certificate chain TP-self-signed-3250545610
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33323530 35343536 3130301E 170D3132 30353234 31343538
34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32353035
34353631 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100CB08 46067C57 C7ACFDD6 CF9DB454 98C1A53B 387D6261 41D32FAA EEAFE100
1239AD29 C14BFB82 B55D9D18 65DDBB17 D2FF3808 1F63DB50 2DA89000 65139967
DBCEEE41 6769F6C8 FDA9BFEA 8466C4ED 9722E23E C9EB8FD7 5DA9839A A450CECC
3E33FEAC 439C8976 68B85C09 2E8F9EB4 5BE9DCF6 58F0FB2D CA762F12 26A71F2F
DE450203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 149EABBF 6C2C469E EABC60C8 ACF7B82E FAAD41B5 41301D06
03551D0E 04160414 9EABBF6C 2C469EEA BC60C8AC F7B82EFA AD41B541 300D0609
2A864886 F70D0101 05050003 81810002 3EFD99E0 19A278AD 26F32BD0 68330BB5
62DCEDAD E9941FD3 E0649F3B F203EE04 CF430275 324CC68E 2C6E6A3F C23F18D2
3147A9DA FC302078 C8CA3995 F61593F0 70F464A2 E2FDE379 45F29734 46E4EDFB
B0141A7F 15127612 217AED54 E05CA407 6710AD93 ED5D4C59 8E5E79D1 C7808D26
35A2F905 BC3FD384 3D03132D 66D496
quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711ulaw
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice translation-rule 1
rule 1 /^0\(.*\)$/ /00\1/
rule 2 /^\([4-9].......\)$/ /0\1/
rule 3 // /00&/
voice translation-rule 2
voice translation-rule 100
rule 1 /\(.*\)/ /\1/ type any unknown plan any unknown
voice translation-profile PSTN_Inbound_Prefixzero
translate calling 1
voice translation-profile outgoingTP
translate called 100
license udi pid C3900-SPE100/K9 sn FOC16175ML6
hw-module pvdm 0/0
file privilege 0
username d3support privilege 15 password 7 020257481E161F2E5E5A
username admin password 7 08021C43040D001B43
redundancy
controller E1 0/0/0
pri-group timeslots 1-10,16
interface Loopback0
ip address 9.9.9.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.130.35.10 255.255.255.0
ip pim sparse-dense-mode
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Dialer1
ip address 192.168.12.1 255.255.255.0
encapsulation ppp
dialer pool 1
dialer remote-name TELSTRA-POC
dialer string 0749703800
dialer-group 1
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip dns server
ip route 0.0.0.0 0.0.0.0 10.130.35.254
access-list 1 permit any
dialer-list 1 protocol ip permit
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:apps45.9-2-1TH1-13.sbn
tftp-server flash:cnu45.9-2-1TH1-13.sbn
tftp-server flash:cvm45sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp45.9-2-1TH1-13.sbn
tftp-server flash:jar45sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP45.9-2-1S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:B016-1-0-4.SBN
tftp-server flash:SCCP6945.9-1-1-0.bin1.sgn
tftp-server flash:SCCP6945.9-1-1-0.bin2.sgn
tftp-server flash:SCCP6945.9-1-1-0.bin3.sgn
tftp-server flash:SCCP6945.9-1-1-0.bin4.sgn
tftp-server flash:SCCP6945.9-1-1-0.loads
tftp-server flash:SCCP6945.9-3-1-3.bin1.sgn
tftp-server flash:SCCP6945.9-3-1-3.bin2.sgn
tftp-server flash:SCCP6945.9-3-1-3.bin3.sgn
tftp-server flash:SCCP6945.9-3-1-3.bin4.sgn
tftp-server flash:SCCP6945.9-3-1-3.loads
tftp-server flash:SCCP6945.9-2-2-4-ES1.bin1.sgn
tftp-server flash:SCCP6945.9-2-2-4-ES1.bin2.sgn
tftp-server flash:SCCP6945.9-2-2-4-ES1.bin3.sgn
tftp-server flash:SCCP6945.9-2-2-4-ES1.bin4.sgn
tftp-server flash:SCCP6945.9-2-2-4-ES1.loads
control-plane
voice-port 0/0/0:15
ccm-manager music-on-hold bind GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.130.35.10 identifier 1 version 4.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register conference
keepalive retries 5
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 5
conference-join custom-cptone jointone
associate application SCCP
dial-peer cor custom
name EMERGENCY
name LOCAL
name LONG-DISTANCE
name INTL
name GLOBAL-OWNED-INTRANET
name MOBILE
dial-peer cor list outgoing-EMERGENCY
member EMERGENCY
dial-peer cor list outgoing-LOCAL
member LOCAL
dial-peer cor list outgoing-LONG-DISTANCE
member LONG-DISTANCE
dial-peer cor list outgoing-INTL
member INTL
dial-peer cor list outgoing-GLOBAL-OWNED-INTRANET
member GLOBAL-OWNED-INTRANET
dial-peer cor list incoming-EMERGENCY
member EMERGENCY
dial-peer cor list incoming-INTL
member EMERGENCY
member LOCAL
member INTL
member MOBILE
dial-peer cor list incoming-LOCAL
member EMERGENCY
member LOCAL
dial-peer cor list outgoing-MOBILE
member MOBILE
dial-peer cor list incoming-LONG-DISTANCE
member EMERGENCY
member LOCAL
member MOBILE
dial-peer cor list incoming-GLOBAL-OWNED-INTRANET
member EMERGENCY
member LOCAL
member MOBILE
dial-peer cor list incoming-MOBILE
member EMERGENCY
member LOCAL
member MOBILE
dial-peer voice 100 pots
trunkgroup PSTN
corlist outgoing outgoing-EMERGENCY
description ### Emergency 000 Calls ###
destination-pattern 0000
forward-digits all
dial-peer voice 101 pots
trunkgroup PSTN
corlist outgoing outgoing-LONG-DISTANCE
description ### Australian Toll Free Numbers ###
destination-pattern 0180[0-1]......
forward-digits all
dial-peer voice 102 pots
trunkgroup PSTN
destination-pattern 0180[2-9]...
forward-digits all
dial-peer voice 103 pots
trunkgroup PSTN
forward-digits all
dial-peer voice 104 pots
trunkgroup PSTN
description ### Australian 1300 Numbers ###
destination-pattern 01300......
forward-digits all
dial-peer voice 105 pots
trunkgroup PSTN
corlist outgoing outgoing-LOCAL
description ### Australian 13XXXX Numbers ###
destination-pattern 013....
forward-digits all
dial-peer voice 106 pots
trunkgroup PSTN
description ### Australian 1345XXXX Numbers ###
destination-pattern 01345....
forward-digits all
dial-peer voice 107 pots
trunkgroup PSTN
description ### Australia Dial Before you Dig ###
destination-pattern 01100
forward-digits all
dial-peer voice 108 pots
trunkgroup PSTN
description ### Australia Operator Services ###
destination-pattern 0119.
forward-digits all
dial-peer voice 109 pots
trunkgroup PSTN
destination-pattern 012[2-3]3
forward-digits all
dial-peer voice 110 pots
trunkgroup PSTN
destination-pattern 0124..
forward-digits all
dial-peer voice 111 pots
trunkgroup PSTN
description ### Australia Call Information Service ###
destination-pattern 01282
forward-digits all
dial-peer voice 112 pots
trunkgroup PSTN
description ### Australia Premium Numbers ###
destination-pattern 0190.......
forward-digits all
dial-peer voice 113 pots
trunkgroup PSTN
description ### Australia STD Numbers ###
destination-pattern 00[235678]........
forward-digits all
dial-peer voice 114 pots
trunkgroup PSTN
corlist outgoing outgoing-MOBILE
description ### Australia Mobile Numbers ###
destination-pattern 004........
forward-digits all
dial-peer voice 115 pots
trunkgroup PSTN
corlist outgoing outgoing-INTL
description ### Australia International Numbers ###
destination-pattern 00011T
forward-digits all
dial-peer voice 116 pots
trunkgroup PSTN
description ### Australia QLD Numbers ###
destination-pattern 0[2-7].......
forward-digits all
dial-peer voice 117 pots
trunkgroup PSTN
description ### Australia 125XXX Numbers ###
destination-pattern 0125...
forward-digits all
dial-peer voice 118 pots
trunkgroup PSTN
description ### Australia 122X Numbers ###
destination-pattern 0122.
forward-digits all
dial-peer voice 119 pots
trunkgroup PSTN
description ### Australia 123X Numbers ###
destination-pattern 0123.
forward-digits all
dial-peer voice 120 pots
trunkgroup PSTN
description ### Australia 1268X Numbers ###
destination-pattern 01268T
forward-digits all
dial-peer voice 121 pots
trunkgroup PSTN
description ### Australia 127 variable Numbers ###
destination-pattern 0127.T
forward-digits all
dial-peer voice 122 pots
trunkgroup PSTN
description ### Australia 1282 Number ###
forward-digits all
dial-peer voice 123 pots
trunkgroup PSTN
description ### Australia 128XX Numbers ###
destination-pattern 0128..
forward-digits all
dial-peer voice 99 pots
destination-pattern 0.T
port 0/0/0:15
forward-digits 10
dial-peer voice 124 pots
trunkgroup PSTN
description ### Australia 13XXXX Free Numbers ###
destination-pattern 13[^0]...
forward-digits all
num-exp 07497883.. 883..
num-exp 497883.. 883..
num-exp 7497883.. 883..
presence
presence call-list
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on ## mute-off **
sdspfarm units 1
sdspfarm tag 1 conference
conference hardware
no auto-reg-ephone
authentication credential appadmin c1sc0Vo!c3
max-ephones 100
max-dn 200
ip source-address 10.130.35.10 port 2000
service phone webAccess 0
timeouts busy 20
timeouts ringing 25
system message POC-IPPBX
cnf-file location flash:
load 7916-24 B016-1-0-4.SBN
load 7965 SCCP45.9-2-1S.loads
load 6945 SCCP6945.9-2-2-4-ES1.loads
time-zone 47
date-format dd-mm-yy
voicemail 03899
max-conferences 8 gain -6
call-park system application
call-forward pattern .T
hunt-group logout HLog
moh "music-on-hold.au"
multicast moh 239.1.1.1 port 16384 route 10.130.35.10 10.130.35.254
web admin system name admin secret 5 $1$BhAC$OmCkPzXPx0wSpok1vxMPR1
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
secondary-dialtone 0
fac standard
create cnf-files version-stamp 7960 Oct 21 2014 22:31:38
ephone-dn-template 1
corlist incoming incoming-GLOBAL-OWNED-INTRANET
pickup-group 1030
allow watch
ephone-template 1
service phone settingAccess 1
softkeys hold Join Newcall Resume Select
softkeys idle Newcall Redial Pickup Cfwdall
softkeys seized Redial Endcall Meetme Pickup
softkeys alerting Callback Endcall
softkeys connected Endcall Trnsfer Hold Park Join Select Confrn
softkeys ringing Answer Dnd
fastdial 1 88300 name Reception
keep-conference
max-calls-per-button 2
type 6945
ephone-template 2
keep-conference
type 7965
ephone-dn 1 dual-line
number 88301
pickup-group 1
ephone-dn 2 dual-line
number 88302
pickup-group 1
ephone-dn 3 dual-line
number 88303
ephone-dn 4 dual-line
number 88304
allow watch
ephone-dn 5 dual-line
number 88305
ephone-dn 6 dual-line
number 88306
ephone-dn 7 dual-line
number 88307
ephone-dn 8 dual-line
number 88308
ephone-dn 9 dual-line
number 88309
ephone-dn 10 dual-line
number 88310
ephone-dn 11 dual-line
number 88311
ephone-dn 12 dual-line
number 88312
ephone-dn 13 dual-line
number 88313
ephone-dn 14 dual-line
number 88314
ephone-dn 15 dual-line
number 88315
ephone-dn 16 dual-line
number 88316
ephone-dn 17 dual-line
number 88317
ephone-dn 18 dual-line
number 88318
ephone-dn 19 dual-line
number 88319
ephone-dn 20 dual-line
number 88320
ephone-dn 21 dual-line
number 88321
ephone-dn 22 dual-line
number 88322
ephone-dn 23 dual-line
number 88323
ephone-dn 24 dual-line
number 88324
ephone-dn 25 dual-line
number 88325
ephone-dn 26 dual-line
number 88326
ephone-dn 27 dual-line
number 88327
ephone-dn 28 dual-line
number 88328
ephone-dn 29 dual-line
number 88329
ephone-dn 30 dual-line
number 88330
ephone-dn 31 dual-line
number 88331
ephone-dn 32 dual-line
number 88332
ephone-dn 33 dual-line
number 88333
ephone-dn 34 dual-line
number 88334
ephone-dn 35 dual-line
number 88335
ephone-dn 36 dual-line
number 88336
ephone-dn 37 dual-line
number 88337
ephone-dn 38 dual-line
number 88338
ephone-dn 39 dual-line
number 88339
ephone-dn 40 dual-line
number 88340
ephone-dn 41 dual-line
number 88341
ephone-dn 42 dual-line
number 88342
ephone-dn 43 dual-line
number 88343
ephone-dn 44 dual-line
number 88344
ephone-dn 45
number 88310
hold-alert 30 originator
ephone-dn 46 dual-line
number 88346
ephone-dn 47 dual-line
number 88347
ephone-dn 48 dual-line
number 88348
ephone-dn 49 dual-line
number 88349
ephone-dn 50 dual-line
number 88350
ephone-dn 80 octo-line
number 87720
conference ad-hoc
preference 1
no huntstop
ephone-dn 81 octo-line
number 87721
conference ad-hoc
preference 1
no huntstop
ephone-dn 82 octo-line
number 87722
conference ad-hoc
preference 1
no huntstop
ephone-dn 83 octo-line
number 87723
conference ad-hoc
preference 1
no huntstop
ephone-dn 84 octo-line
number 87724
conference ad-hoc
preference 1
no huntstop
ephone-dn 85 octo-line
number 87725
conference ad-hoc
preference 1
no huntstop
ephone-dn 86 octo-line
number 87726
conference ad-hoc
preference 1
no huntstop
ephone-dn 87 octo-line
number 87727
conference ad-hoc
preference 1
no huntstop
ephone-dn 88 octo-line
number 87728
conference ad-hoc
preference 1
no huntstop
ephone-dn 89 octo-line
number 87729
conference ad-hoc
preference 1
no huntstop
ephone-dn 90 octo-line
number 87710
conference meetme
preference 1
no huntstop
ephone-dn 91 octo-line
number 87711
conference meetme
preference 1
no huntstop
ephone-dn 92 octo-line
number 87712
conference meetme
preference 1
no huntstop
ephone-dn 93 octo-line
number 87713
conference meetme
preference 1
no huntstop
ephone-dn 94 octo-line
number 87714
conference meetme
preference 1
no huntstop
ephone-dn 95 octo-line
number 87715
conference meetme
preference 1
no huntstop
ephone-dn 96 octo-line
number 87716
conference meetme
preference 1
no huntstop
ephone-dn 97 octo-line
number 87717
conference meetme
preference 1
no huntstop
ephone-dn 98 octo-line
number 87718
conference meetme
preference 1
no huntstop
ephone-dn 99 octo-line
number 87719
conference meetme
preference 1
no huntstop
ephone-dn 100 dual-line
number 88300
label Reception - 88300
ephone-dn 110 dual-line
number 9090
park-slot timeout 20 limit 2 recall
ephone-dn 111 dual-line
number 9091
ephone-dn 112 dual-line
number 9092
ephone-dn 113 dual-line
number 9093
ephone-dn 114 dual-line
number 9094
ephone-dn 115 dual-line
number 9095
ephone-dn 116 dual-line
number 9096
ephone-dn 117 dual-line
number 9097
ephone-dn 118 dual-line
number 9098
ephone-dn 119 dual-line
number 9099
ephone-dn 120 dual-line
number 9010
park-slot directed timeout 20 limit 2 recall
ephone-dn 121
number 9011
ephone-dn 122
number 9012
ephone-dn 123
number 9013
ephone-dn 124
number 9014
ephone-dn 125
number 9015
ephone 1
mac-address 34BD.C82C.B42B
ephone-template 1
username "phone1" password 12345
type 7975
button 1:1
ephone 2
mac-address 34BD.C8C6.870D
ephone-template 1
username "phone2" password 12345
type 7942
button 1:2
ephone 3
mac-address 442B.0319.7D8D
ephone-template 1
username "phone3" password 12345
type 6945
button 1:3
ephone 4
mac-address 442B.0319.7D88
ephone-template 1
username "phone4" password 12345
fastdial 1 88200 name reception
type 6945
button 1:4
ephone 5
mac-address 34BD.C82C.76BD
ephone-template 1
username "phone5" password 12345
type 7942
button 1:5
ephone 6
mac-address 34BD.C82C.2687
ephone-template 1
username "phone6" password 12345
type 7942
button 1:6
ephone 7
mac-address 34BD.C82C.A875
ephone-template 1
username "phone7" password 12345
type 7942
button 1:7
ephone 8
mac-address 34BD.C82C.A876
ephone-template 1
username "phone8" password 12345
type 7942
button 1:8
ephone 9
mac-address 34BD.C82C.A87E
ephone-template 1
username "phone9" password 12345
type 7942
button 1:9
ephone 10
mac-address 34BD.C82C.B55D
ephone-template 1
username "phone10" password 12345
type 7942
button 1:10
ephone 11
mac-address 34BD.C82C.7670
ephone-template 1
username "phone11" password 12345
type 7942
button 1:11
ephone 12
mac-address 34BD.C82D.D262
ephone-template 1
username "phone12" password 12345
type 7942
button 1:12
ephone 13
mac-address 34BD.C82C.2454
ephone-template 1
username "phone13" password 12345
type 7942
button 1:13
ephone 14
mac-address 442B.0319.5A71
ephone-template 1
username "phone14" password 12345
type 6945
button 1:45
ephone 15
mac-address 34BD.C82C.A530
ephone-template 1
username "phone15" password 12345
type 7942
button 1:15
ephone 16
mac-address 0CD9.9690.8AA9
ephone-template 1
username "phone16" password 12345
type 7942
button 1:16
ephone 17
mac-address 442B.0319.777F
ephone-template 1
username "phone17" password 12345
type 6945
button 1:17
ephone 18
mac-address 34BD.C82C.24F7
ephone-template 1
username "phone18" password 12345
fastdial 1 0435295811 name j
speed-dial 1 1111 label "test"
speed-dial 2 0435295811 label "t"
type 7942
button 1:18
ephone 19
mac-address 442B.0319.76C5
ephone-template 1
username "phone19" password 12345
type 6945
button 1:19
ephone 20
mac-address 442B.0319.7776
ephone-template 1
username "phone20" password 12345
type 6945
button 1:20
ephone 21
mac-address 442B.0319.7D90
ephone-template 1
username "phone21" password 12345
type 6945
button 1:21
ephone 22
mac-address 442B.0319.7827
ephone-template 1
username "phone22" password 12345
type 6945
button 1:22
ephone 23
mac-address 442B.0319.7665
ephone-template 1
username "phone23" password 12345
type 6945
button 1:23
ephone 24
mac-address 442B.0319.776F
ephone-template 1
username "phone24" password 12345
type 6945
button 1:24
ephone 25
mac-address 442B.0319.5803
ephone-template 1
username "phone25" password 12345
type 6945
button 1:25
ephone 26
mac-address 442B.0319.57FB
ephone-template 1
username "phone26" password 12345
type 6945
button 1:26
ephone 27
mac-address 442B.0319.74D1
ephone-template 1
username "phone27" password 12345
type 6945
button 1:27
ephone 28
mac-address 442B.0319.76B0
ephone-template 1
username "phone28" password 12345
type 6945
button 1:28
ephone 29
mac-address 442B.0319.76CE
ephone-template 1
username "phone29" password 12345
type 6945
button 1:29
ephone 30
mac-address 442B.0319.77FE
ephone-template 1
username "phone30" password 12345
type 6945
button 1:30
ephone 31
mac-address 442B.0319.740F
ephone-template 1
username "phone31" password 12345
type 6945
button 1:31
ephone 32
mac-address 442B.0319.76DE
ephone-template 1
username "phone32" password 12345
type 6945
button 1:32
ephone 33
mac-address 442B.0319.772A
ephone-template 1
username "phone33" password 12345
type 6945
button 1:33
ephone 34
mac-address 442B.0319.7A7C
ephone-template 1
username "phone34" password 12345
type 6945
button 1:34
ephone 35
mac-address 442B.0319.7306
ephone-template 1
username "phone35" password 12345
type 6945
button 1:35
ephone 36
mac-address 442B.0319.76D9
ephone-template 1
username "phone36" password 12345
type 6945
button 1:36
ephone 37
mac-address 442B.0319.7B03
ephone-template 1
username "phone37" password 12345
type 6945
button 1:37
ephone 38
mac-address 442B.0319.7707
ephone-template 1
username "phone38" password 12345
type 6945
button 1:38
ephone 39
mac-address 442B.0319.76F9
ephone-template 1
username "phone39" password 12345
type 6945
button 1:39
ephone 40
mac-address 442B.0319.775D
ephone-template 1
username "phone40" password 12345
type 6945
button 1:40
ephone 41
mac-address 442B.0319.6E2F
ephone-template 1
username "phone41" password 12345
type 6945
button 1:41
ephone 42
mac-address 442B.0319.76F4
ephone-template 1
username "phone42" password 12345
type 6945
button 1:42
ephone 43
mac-address 0C27.24BA.9C4B
ephone-template 1
username "phone43" password 12345
type 6945
button 1:43
ephone 44
mac-address 0C27.24BA.9CDE
ephone-template 1
username "phone44" password 12345
type 6945
button 1:44
ephone 100
mac-address F4EA.6748.F991
ephone-template 2
username "reception" password 12345
presence call-list
fastdial 1 00749788619 name Lesley Mohr
fastdial 2 00746298606 name Alicia Humphreys
fastdial 3 00738383978 name Greg Bishop
fastdial 4 00881167777 name Service Centre
fastdial 5 00749788410 name Amanda Horvath
fastdial 6 00749788561 name Kylie Williams
speed-dial 1 00749788619 label "Lesley Mohr"
speed-dial 2 00746298606 label "Alicia Humphreys"
speed-dial 3 00738383978 label "Greg Bishop"
speed-dial 4 00749788410 label "Amanda Horvath"
speed-dial 5 00749788561 label "Kylie Williams"
speed-dial 6 00881167777 label "Service Centre"
speed-dial 7 00746298617 label "EQ Pipeline Supervisor"
speed-dial 8 00746298622 label "EQ Pipeline Coordinator"
type 7965 addon 1 7916-24
button 1:100
banner exec ^C
this session.
use.
^C
banner login ^C
CREDENTIALS
no username cisco
to use.
^C
line con 0
login authentication console
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
POCPBX01#
