Cisco 8821 wriless phone not registering with CUCM
Hello, cisco 8821 wireless phone not registering with the CUCM.
When powering off and then bring it back it works (registering ) sometimes but not all times that kind of restarting helps.
When changing to connect another SSID and the connecting back former SSID it works.
ALL of these attempts not fixing the registering problem after 1 or 2 days or 1-2 hours it beeing unregister.
CUCM  System version: 12.5.1.10000-22
Can anyone encounter this kind of problem?
After changing wifi ap from 2.4 GHz to 5ghz  problem has been solved.
11 Replies 11
Leo Laohoo
What firmware is the phone running on?
Firmware version is sip8821.11-0-4sr2-15
How many phones are affected by this?
we have only one wireless phone and only that phone connected access point .
I am trying to look logs from 8821 but only it shows only logs when it was registered state. After losing registration it won`t show logs .
I'm trying to determine if this is a CUCM issue or a wireless issue.
So when this issue occurs, is the phone joined to the wireless or not.
The phone just getting unregistered after reboot or some time. Time is not the same all-time for ex one time it gets 1 day after, another time it gets 10 days later and sometimes it gets 1 hour.
IT still connected wireless network but get unregistered state. we check thought ICMP to phone responding.
OK, so the phone is still connected to WiFi when this issue occurs.
Have you checked the phone and CUCM logs and see if there are anything unusual?
What QoS is the SSID the phone is connected to?
When the phone got an unregistered state I can`t log into the phone to saw logs.
we don`t use a wireless connection in our environment but only we bought an Ap for only cisco 8821.
So that Ap has a very basic setting not have a QoS setting.
user64595
Same issue with sip8821.11-0-6SR5-5.
Configuring my basic AP like this : "Voice QoS", 5GHz, beacon 1, dtime 2, proxy  ARP and removing 802.11k .  It is much more better.
