06-09-2016 09:01 PM - edited 03-17-2019 07:11 AM
Hi All,
i just installed a 8831 phone in CME 10.5
the phone is working fine , but i found that the phone time display on 8831 is incorrect (other mode is ok).
and one know what happened?
thanks
Simon
06-09-2016 09:40 PM
Please make sure correct phone type is defined in voice register pool and also timezone value needs to be appropriate for whatever local time is.
Paste the config if above things are checked.thanks
06-09-2016 11:06 PM
hi Deepak
i found that should be the bug of 8831 in CME
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuq48737/?referring_site=bugquickviewredir
and i already follow the post to change the phone type and problem still exist .
any idea about it?
thanks
06-10-2016 05:57 AM
Did you do create
10-31-2018 09:41 PM
Hi all
this command has made life easy ,, works perfectly
happy to help
Copy the "TzDataCSV.csv" and "tzupdater.jar into CME router flash.
tftp-server flash:TzDataCSV.csv
tftp-server flash:tzupdater.jar
voice register global
olsontimezone xxxx/xxxxxx version 2015a
no create profile
create profile
reset
4-voice register pool
Apply-config
regards
Muralidharan
