Cisco 8851 with Webex Calling
rab.j.choudhry
I'm trying to follow Configure Monitoring of an Individual Line in the 8800 User Guide
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/MPP/8800/english/userguide/p881_b_8800-3pcc-user-guide/p881_b_8800-3pcc-user-guide-110_chapter_00.html#reference_7C1EEBB096A423291EB43839261D8D3B
However, I only see 2 Options
1 None
2 Speed Dial
I do not see the rest as outlined in Step 2 below.
Step 1
Press and hold down the line key for two seconds.
Step 2
On the Select feature screen, select one of these options:
  • If you just want to use the key to monitor a line, select BLF presence.
  • If you want to use the key to monitor a line and also speed-dial the monitored line, select BLF + Speed dial.
  • If you want to use the key to monitor a line and also answer incoming calls to the monitored line, select BLF + Call pickup.
  • If you want to use the key for all the three functions, select BLF + Speed dial + Call pickup.
Jaime Valencia
Are you sure you're running 3PCC FW?
java
if this helps, please rate
Yes, we are using Webex Calling
