Cisco Callmanager timestamp configured / changed DN
mischm
is there any way to find out ìn Cisco Callmanager 8.6.2 via SQL / AXL or in the web-gui how many and which DN`s are configured or changed in the last 2 months?
BR
Michael
Jaime Valencia
Use role based logs for such matter, this has been discussed plenty times before, if you need further info, search CSC for the topic.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime,
thanks for your answer.
So RTMT maybe can help me in this issue?
https://supportforums.cisco.com/message/3120420#3120420 -> "Take a look at the 'Role-Based Security' logs via RTMT's Collect Logs feature."
BR
Michael
