Cisco CP-6901 SIP
danut.sintion
I have a question regards a Cisco Phone 6901.
I just bought 3 to use with my SIP PBX, i didn`t know that is so hard to config this phone in order to work with SIP. I spended all the day to find out how to upgrade to SIP firmware and now i`m stuck at SEPXXXXXXXXXX.cnf.xml i cannot find a exemple for this phone model.
Maybe someone with call manager can help me with this file, in this moment the phone is keep asking the tftp server for files in loop i guess that the SEP.cnf.xml is not right.
Thanks a lot.
danut.sintion
May 12 23:59:17 localhost in.tftpd[22471]: RRQ from 192.168.191.84 filename SEP2C31246EDCF6.cnf.xml
May 12 23:59:17 localhost in.tftpd[22472]: RRQ from 192.168.191.84 filename XMLDefault.cnf.xml
May 12 23:59:18 localhost in.tftpd[22473]: RRQ from 192.168.191.84 filename SIP6901.9-3-1-SR2-3.loads
May 12 23:59:48 localhost in.tftpd[22475]: RRQ from 192.168.191.84 filename CTLSEP2C31246EDCF6.tlv
May 12 23:59:48 localhost in.tftpd[22475]: sending NAK (1, File not found) to 192.168.191.84
May 12 23:59:48 localhost in.tftpd[22476]: RRQ from 192.168.191.84 filename SEP2C31246EDCF6.cnf.xml
May 12 23:59:48 localhost in.tftpd[22477]: RRQ from 192.168.191.84 filename XMLDefault.cnf.xml
May 12 23:59:49 localhost in.tftpd[22478]: RRQ from 192.168.191.84 filename SIP6901.9-3-1-SR2-3.loads
May 13 00:00:19 localhost in.tftpd[22510]: RRQ from 192.168.191.84 filename CTLSEP2C31246EDCF6.tlv
May 13 00:00:19 localhost in.tftpd[22510]: sending NAK (1, File not found) to 192.168.191.84
May 13 00:00:19 localhost in.tftpd[22511]: RRQ from 192.168.191.84 filename SEP2C31246EDCF6.cnf.xml
May 13 00:00:19 localhost in.tftpd[22513]: RRQ from 192.168.191.84 filename XMLDefault.cnf.xml
May 13 00:00:20 localhost in.tftpd[22514]: RRQ from 192.168.191.84 filename SIP6901.9-3-1-SR2-3.loads
Judging from the logs above, I can say the phone is "hitting" the TFTP server, which means DHCP Option 150 is working (correctly).
So this means you'll need a few more files:
  1. The phone configuration file, SEP2C31246EDCF6.cnf.xml;
  2. SIP firmware version 9.3(1)SR2;
  3. XMLDefault.cnx.xml file; and
  4. Dialing plan file
Thank you for your time, now is working finally i find`it out.
The problem was in freepbx, i have to enable voice over tcp, default is on UDP and cisco knows SIP only on TCP. After this changes the phone register without problemes.
Can be closed.
