05-14-2017 11:39 PM - edited 03-17-2019 10:19 AM
I have 7960 Phones registered to Non Cisco CM
There are couple of phone are on SCCP firmware which need to be updated on SIP in order to registere
Trying TFTPD32 and updating the SIP firmware but its not getting updated
TFTP Logs shows as below
Connection received from 10.123.57.76 on port 50486 [12/05 20:31:45.169]
Read request for file <CTLSEPACA016FCAA50.tlv>. Mode octet [12/05 20:31:45.169]
File <CTLSEPACA016FCAA50.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [12/05 20:31:45.169]
Connection received from 10.123.57.76 on port 50487 [12/05 20:31:45.185]
Read request for file <SEPACA016FCAA50.cnf.xml>. Mode octet [12/05 20:31:45.185]
Using local port 52995 [12/05 20:31:45.185]
<SEPACA016FCAA50.cnf.xml>: sent 1 blk, 0 bytes in 0 s. 0 blk resent [12/05 20:31:45.247]
Connection received from 10.123.57.76 on port 50084 [12/05 20:33:18.130]
Read request for file <CTLSEPACA016FCAA50.tlv>. Mode octet [12/05 20:33:18.130]
File <CTLSEPACA016FCAA50.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [12/05 20:33:18.130]
Connection received from 10.123.57.76 on port 50085 [12/05 20:33:18.270]
Read request for file <SEPACA016FCAA50.cnf.xml>. Mode octet [12/05 20:33:18.270]
Using local port 52997 [12/05 20:33:18.270]
<SEPACA016FCAA50.cnf.xml>: sent 1 blk, 0 bytes in 0 s. 0 blk resent [12/05 20:33:18.348]
05-15-2017 03:57 AM
The filename "SEPACA016FCAA50.cnf.xml" is not found in the TFTP server. The file "SEPACA016FCAA50.cnf.xml" contains the SIP firmware the phone is meant to download.
